Im new to this and couldn't find any resource for my specific question. I have a custom field that was we created called UX/PO/QA Approval. The closest I can find is the Issue Trigger "Field Value Changed" but that doesn't suffice. I want to create a rule that does the following:
If the Epic is in PO/UX Review and the UX/PO/QA Approval has "QA Approval", "UX Approval", and "PO Approval" (All 3), then transition the epic status from PO/UX Review to "Ready To Deploy to UAT".
Hi @Ryan_Smith,
The way I would create the automation would be to use the Field value change trigger and use the issue fields condition to check it the UX/PO/QA Approval field has all three values and if that is the case then transition the epic.
Something like this should do it:
In this example I'm using the labels field, but the principal is the same for your use case.
That Worked! thanks, I want to add in the condition that will only change if its in PO/UX Review epic status, any suggestions?
