×Hi all, I'm developing a jira plugin custom field extends SelectCFType class, and I Override the OptionsManager.getOptions() function, but when I refresh the portal, the options will be rendered repeatedly like below. Could anyone solve this?
And here's my getOptions funciton.
@Override
public Options getOptions(FieldConfig fieldConfig, JiraContextNode jiraContextNode){
try {
List<Option> options = new ArrayList<>();
IQLFacade iqlFacade = ComponentAccessor.getOSGiComponentInstanceOfType(IQLFacade.class);
String iql = "Key != \"\"";
List<ObjectBean> assets = iqlFacade.findObjects(iql);
log.debug(assets.toString());
for(ObjectBean asset : assets){
String key = asset.getObjectKey();
Integer id = asset.getId();
log.debug(key);
log.debug(id.toString());
options.add(ComponentAccessor.getOptionsManager().createOption(fieldConfig,null,Long.valueOf(id),key));
log.debug(options.toString());
return new OptionsImpl(options,fieldConfig,ComponentAccessor.getOptionsManager());
} catch (InsightException e) {
throw new RuntimeException(e);
Any adivce will be appreciated. Thanks in advance.
Hi @Wenjing Liu
The root cause of the problem is the line below:
options.add(ComponentAccessor.getOptionsManager().createOption(fieldConfig, null, Long.valueOf(id), key));
@Override
public Options getOptions(FieldConfig fieldConfig, JiraContextNode jiraContextNode) {
List<Option> existingOptions = ComponentAccessor.getOptionsManager().getOptions(fieldConfig);
return new OptionsImpl(existingOptions, fieldConfig, ComponentAccessor.getOptionsManager());
Oh I see. I solved this problem using your method. Thanks very much!
Thanks very much for your advice! And I'm sorry that I have another question How to develop an Asset Picker? Could you please help me if you have some time? Any advice will be greatly appreciated. Thanks in advance!
