Is there a way to show and hide fields on create screen based on value selected for other field
Example:
On a JWM create screen, I have a field called:
Is Approval Required: Yes or NO (dropdown)
If Yes is selected, should show another fields on the screen,
if No is selected, no need to show any new fields.
And there is no customer portal, we create issues from create button only.
This is for JWM project on Jira cloud.
We have Customer Form Extension plugin on JSD for the same, but I couldn't use the same plugin for JWM. There is no option to configure this plugin on my JWM project.
Can someone suggest if there is any option to achieve this behavior.
Thanks.
Hello @Rompicherla Kalyani
There is no native support for conditionally displaying fields in the Create Issue dialog.
You can achieve that with third party plugins.
The Behaviours app from Adaptavist would enable you to achieve your goal. The Behaviours app itself is free, but it requires their ScriptRunner app to be enabled also, and that is not free.
@Trudy Claspill I believe scriptRunner and Behaviors are useful for Jira server only right?
We are using Jira cloud.
Hi Rompicherla,
Atlassian enabled us to write a lot of Behaviours for Cloud a while ago. It is not as flexible as the Server/DC Behaviours, but it can do a lot, including "field options based on other selections"
Understand, Thanks for the update.
By anychance, can we make use of Customer Form Extension plugin for this requirement on JWM project?
I'm not finding "Customer Form Extension" as an app in the Atlassian Marketplace.
https://marketplace.atlassian.com/search?query=customer%20form%20extension
Have you tried contacting the app vendor to ask that question?
