Jira automation - smart values conditional logic does not return true
Andreas Eichert
April 3, 2022
I'm trying to create a simple automation based on due dates.
I have a smart variable dueInDays:
{{#=}}{{now.diff(issue.dueDate).days}}+1{{/}}
I've tried several variants, but I cannot get the if-condition to return "Hello".
due in: {{dueInDays}}
{{#if(dueInDays.gt(0))}} Hello {{/}}
I was following the documentation here (numerical comparisons): https://support.atlassian.com/cloud-automation/docs/jira-smart-values-math-expressions/
Any ideas? :)
Stefan Salzl
Hi @Andreas Eichert
Could you describe your use case from a functional perspective? As this could maybe be resolved with a condition component in automation rather than within smart value condition.
So condition could be checked up front and only in case of fullfillment mail is sent.
Please let me know what exactly should happen when in order to find the best solution according to the requirement.
Best
Stefan
Stefan Salzl
I also got the conditional smart value working. Please try following and let me know if it works for you too:
{{#if(dueInDays.asNumber.gt(0))}} Hello {{/}}
Best
Stefan
Like # people like this
Andreas Eichert
April 4, 2022
That solves it. Thanks a lot!
I was also looking for casting to a number but could not find anything straight away.
And yes, it could probably be solved with a condition and just sending two different types of mails instead of formatting a mail.
Use case is sending reminders based on the due date. I want to send
"Your task is due tomorrow." instead of "Your task is due in 1 days.".
Fabian Lim
Hi @Andreas Eichert
Use the log action to see whether the first variable is set properly.  Instructions: https://support.atlassian.com/cloud-automation/docs/debug-an-automation-rule/
Regards
