Manual Trigger Automation - Prompt Date Custom Field Input
Keiko Kamiya
Hello Atlassian Community,
I am trying to utilize the manual trigger automation to allow the user to input the custom date fields, however, there are no date field options from this list:
I tried using text as date but that didn't translate well. Can someone confirm we're unable to have a date-picker for this type of trigger? Thank you!
9 votes
Bill Sheboy
July 11, 2025
Hi @Keiko Kamiya
Correct: the date and date / time types are not supported for a Manual Trigger's user input options yet.  That is one of the suggested improvements to the trigger, which you may watch / vote for here: https://jira.atlassian.com/browse/AUTO-744
As a workaround, please use a Short Text field, and later convert it with the toDate function:
https://support.atlassian.com/cloud-automation/docs/examples-of-using-smart-values-with-dates/#Converting-text-to-dates
Keiko Kamiya
Very helpful, thanks Bill!
Like # people like this
Yatish Madhav
July 15, 2025
Thanks @Bill Sheboy - I was about to implement something like this as well.
Also, thanks for the ticket to upvote, watch and comment on
Yatish
