×I am trying to compile my plugin. But plugin is not getting enabled and i have this error:
Unresolved constraint in bundle [114]: Unable to resolve 114.0: missing requirement [114.0] osgi.wiring.package; (osgi.wiring.package=[package name])
I meet so many errors of this type and I added the missing package to <Export-Package> one by one as you can see below. But this is very annoying and is there any other solutions to this problem?
I tried other answers from here, but it doesn't work for me.
Any advice and help will be greatly appreciated. Thanks for you all in advance.
My pom:
<?xml version="1.0" encoding="UTF-8"?>
<project xmlns="http://maven.apache.org/POM/4.0.0"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/maven-v4_0_0.xsd">
<modelVersion>4.0.0</modelVersion>
<groupId>com.ms.plugins.cmdb.jira</groupId>
<artifactId>cmdb-jira-custom-field</artifactId>
<version>1.0.0-SNAPSHOT</version>
<organization>
<name>Morgan Stanley</name>
<url>https://www.morganstanley.com/</url>
</organization>
<name>cmdb-jira-custom-field</name>
<description>This is the com.ms.plugins.cmdb.jira:cmdb-jira-custom-field plugin for Atlassian JIRA.</description>
<packaging>atlassian-plugin</packaging>
<dependencyManagement>
<dependencies>
<dependency>
<groupId>net.minidev</groupId>
<artifactId>json-smart</artifactId>
<version>2.4.9</version>
</dependency>
<dependency>
<groupId>org.glassfish.jaxb</groupId>
<artifactId>jaxb-runtime</artifactId>
<version>2.3.6</version>
</dependency>
</dependencies>
</dependencyManagement>
<dependencies>
<dependency>
<groupId>com.atlassian.jira</groupId>
<artifactId>jira-api</artifactId>
<version>${jira.version}</version>
<scope>provided</scope>
<exclusions>
<exclusion>
<groupId>xerces</groupId>
<artifactId>xercesImpl</artifactId>
</exclusion>
<exclusion>
<groupId>org.apache.commons</groupId>
<artifactId>commons-text</artifactId>
</exclusion>
</exclusions>
</dependency>
<!-- Add dependency on jira-core if you want access to JIRA implementation classes as well as the sanctioned API. -->
<!-- This is not normally recommended, but may be required eg when migrating a plugin originally developed against JIRA 4.x -->
<dependency>
<artifactId>jira-core</artifactId>
<exclusions>
<exclusion>
</exclusion>
<exclusion>
<groupId>hsqldb</groupId>
<artifactId>hsqldb</artifactId>
</exclusion>
<exclusion>
<groupId>net.sf.ehcache</groupId>
<artifactId>ehcache</artifactId>
</exclusion>
</exclusions>
</dependency>
<dependency>
<groupId>junit</groupId>
<artifactId>junit</artifactId>
<version>4.10</version>
<scope>test</scope>
</dependency>
<dependency>
<groupId>com.atlassian.plugin</groupId>
<artifactId>atlassian-spring-scanner-annotation</artifactId>
<version>${atlassian.spring.scanner.version}</version>
</dependency>
<dependency>
<artifactId>atlassian-spring-scanner-runtime</artifactId>
<version>${atlassian.spring.scanner.runtime.version}</version>
</dependency>
<dependency>
<groupId>javax.inject</groupId>
<artifactId>javax.inject</artifactId>
<version>1</version>
</dependency>
<!-- WIRED TEST RUNNER DEPENDENCIES -->
<dependency>
<groupId>com.atlassian.plugins</groupId>
<artifactId>atlassian-plugins-osgi-testrunner</artifactId>
<version>${plugin.testrunner.version}</version>
<scope>test</scope>
</dependency>
<dependency>
<groupId>javax.ws.rs</groupId>
<artifactId>jsr311-api</artifactId>
<version>1.1.1</version>
</dependency>
<!-- <dependency>-->
<!-- <groupId>com.google.code.gson</groupId>-->
<!-- <artifactId>gson</artifactId>-->
<!-- <version>2.2.2-atlassian-1</version>-->
<!-- </dependency>-->
<!-- Uncomment to use TestKit in your project. Details at https://bitbucket.org/atlassian/jira-testkit -->
<!-- You can read more about TestKit at https://developer.atlassian.com/display/JIRADEV/Plugin+Tutorial+-+Smarter+integration+testing+with+TestKit -->
<dependency>
<groupId>com.atlassian.jira.tests</groupId>
<artifactId>jira-testkit-client</artifactId>
<version>${testkit.version}</version>
<scope>test</scope>
</dependency>
<dependency>
<groupId>org.slf4j</groupId>
<artifactId>slf4j-api</artifactId>
<version>1.7.36</version>
</dependency>
<dependency>
<groupId>org.mockito</groupId>
<artifactId>mockito-all</artifactId>
<version>1.8.5</version>
<scope>test</scope>
</dependency>
<dependency>
<groupId>org.projectlombok</groupId>
<artifactId>lombok</artifactId>
<version>1.18.38</version>
</dependency>
<dependency>
<groupId>com.atlassian.sal</groupId>
<artifactId>sal-api</artifactId>
<version>5.2.0</version>
</dependency>
<dependency>
<groupId>com.google.code.findbugs</groupId>
<artifactId>annotations</artifactId>
<version>3.0.0</version>
<exclusions>
<exclusion>
<groupId>com.google.errorprone</groupId>
<artifactId>error_prone_annotations</artifactId>
</exclusion>
</exclusions>
</dependency>
<dependency>
<groupId>com.atlassian.jira.plugins</groupId>
<artifactId>insight</artifactId>
<version>10.13.1</version>
</dependency>
<dependency>
<groupId>com.atlassian.servicedesk</groupId>
<artifactId>insight-core-model</artifactId>
</dependency>
<dependency>
<artifactId>insight-core-services</artifactId>
<scope>compile</scope>
</dependency>
<dependency>
<artifactId>insight-core-utils</artifactId>
</dependency>
<dependency>
<artifactId>insight-external-services</artifactId>
</dependency>
<dependency>
<artifactId>insight-core-index</artifactId>
</dependency>
<dependency>
<artifactId>insight-core-iql</artifactId>
</dependency>
<dependency>
<groupId>com.atlassian.event</groupId>
<artifactId>atlassian-event</artifactId>
<version>5.1.0</version>
</dependency>
<dependency>
<groupId>org.springframework</groupId>
<artifactId>spring-beans</artifactId>
<version>5.3.33</version>
</dependency>
<dependency>
<artifactId>spring-context</artifactId>
</dependency>
<dependency>
<groupId>jakarta.validation</groupId>
<artifactId>jakarta.validation-api</artifactId>
<version>2.0.2</version>
</dependency>
</dependencies>
<build>
<plugins>
<plugin>
<groupId>com.atlassian.maven.plugins</groupId>
<artifactId>jira-maven-plugin</artifactId>
<version>${amps.version}</version>
<extensions>true</extensions>
<configuration>
<productVersion>${jira.version}</productVersion>
<productDataVersion>${jira.version}</productDataVersion>
<log4jProperties>src/aps/log4j.properties</log4jProperties>
<!-- Uncomment to install TestKit backdoor in JIRA. -->
<pluginArtifacts>
<pluginArtifact>
<artifactId>jira-testkit-plugin</artifactId>
</pluginArtifact>
</pluginArtifacts>
<enableQuickReload>true</enableQuickReload>
<!-- See here for an explanation of default instructions: -->
<!-- https://developer.atlassian.com/docs/advanced-topics/configuration-of-instructions-in-atlassian-plugins -->
<instructions>
<Atlassian-Plugin-Key>${atlassian.plugin.key}</Atlassian-Plugin-Key>
<!-- Add package to export here -->
<Export-Package>
com.ms.plugins.cmdb.jira.customfields.api,
android.os,
com.mindville.insight.services.model,
kotlin.reflect.jvm.internal,
org.ehcache.impl.internal.concurrent,
com.sun.tools.javac.code,
com.sun.tools.javac.util,
io.riada.insight.index,
com.sun.xml.fastinfoset.sax,
com.sun.xml.fastinfoset.stax,
io.riada.insight.file,
javax.enterprise.util,
org.antlr.v4.runtime,
org.antlr.v4.runtime.atn,
org.antlr.v4.runtime.dfa,
org.antlr.v4.runtime.tree,
org.eclipse.jdt.internal.compiler,
org.eclipse.jdt.internal.compiler.apt.model,
org.eclipse.jdt.internal.compiler.ast,
org.eclipse.jdt.internal.compiler.env,
org.eclipse.jdt.internal.compiler.lookup,
org.glassfish.hk2.osgiresourcelocator,
org.jvnet.fastinfoset,
org.jvnet.fastinfoset.stax,
org.jvnet.staxex,
com.riadalabs.jira.plugins.insight.common.tools,
com.riadalabs.jira.plugins.insight.services.core.dal,
com.riadalabs.jira.plugins.insight.services.model.graph,
com.riadalabs.jira.plugins.insight.services.model.icontheme,
com.riadalabs.jira.plugins.insight.services.user,
io.riada.insight.utils,
io.riada.insight.services.comparator,
io.riada.insight.common,
io.riada.insight.external.services,
io.riada.insight.featureflags,
io.riada.insight.index.cache,
io.riada.insight.index.filter,
com.google.errorprone.annotations,
com.google.errorprone.annotations.concurrent
</Export-Package>
<!-- Add package import here -->
<Import-Package>
org.springframework.osgi.*;resolution:="optional",
org.eclipse.gemini.blueprint.*;resolution:="optional",
</Import-Package>
<!-- Ensure plugin is spring powered -->
<Spring-Context>*</Spring-Context>
</instructions>
</configuration>
</plugin>
<plugin>
<artifactId>atlassian-spring-scanner-maven-plugin</artifactId>
<executions>
<execution>
<goals>
<goal>atlassian-spring-scanner</goal>
</goals>
<phase>process-classes</phase>
</execution>
</executions>
<configuration>
<scannedDependencies>
<dependency>
<artifactId>atlassian-spring-scanner-external-jar</artifactId>
</dependency>
</scannedDependencies>
<verbose>false</verbose>
</configuration>
</plugin>
</plugins>
</build>
<properties>
<jira.version>9.17.0</jira.version>
<amps.version>9.1.1</amps.version>
<plugin.testrunner.version>2.0.1</plugin.testrunner.version>
<atlassian.spring.scanner.version>4.0.0</atlassian.spring.scanner.version>
<atlassian.spring.scanner.runtime.version>3.0.3</atlassian.spring.scanner.runtime.version>
<!-- This property ensures consistency between the key in atlassian-plugin.xml and the OSGi bundle's key. -->
<atlassian.plugin.key>${project.groupId}.${project.artifactId}</atlassian.plugin.key>
<!-- TestKit version 6.x for JIRA 6.x -->
<testkit.version>6.3.11</testkit.version>
<project.build.sourceEncoding>UTF-8</project.build.sourceEncoding>
<maven.compiler.source>1.8</maven.compiler.source>
<maven.compiler.target>1.8</maven.compiler.target>
</properties>
</project>
Hi @Wenjing Liu
That error means your plugin is importing packages that Jira don’t export. Adding those packages to <Export-Package>
in your bundle won’t fix it. Long story short, you can’t export classes you don’t own. Only export your own API (if another plugin must import it).
I see, thanks very much. But could you please give me some advice on how can I fix this missing requirement osgi.wiring.package error? Here's my import code. I guess the error is from I import ObjectTicketConnectionService?
CmdbCustomField.java
import com.atlassian.jira.issue.context.JiraContextNode;
import com.atlassian.jira.issue.customfields.impl.SelectCFType;
import com.atlassian.jira.issue.customfields.impl.FieldValidationException;
import com.atlassian.jira.issue.customfields.option.Option;
import com.atlassian.jira.issue.customfields.option.Options;
import com.atlassian.jira.issue.customfields.persistence.PersistenceFieldType;
import com.atlassian.plugin.spring.scanner.annotation.imports.JiraImport;
import com.riadalabs.jira.plugins.insight.common.exception.InsightException;
import lombok.NonNull;
import org.slf4j.Logger;
import org.slf4j.LoggerFactory;
import com.atlassian.jira.issue.customfields.persistence.CustomFieldValuePersister;
import com.atlassian.jira.issue.customfields.manager.GenericConfigManager;
import com.atlassian.jira.issue.customfields.manager.OptionsManager;
import com.atlassian.jira.issue.fields.rest.json.beans.JiraBaseUrls;
import com.atlassian.jira.issue.Issue;
import com.atlassian.jira.issue.fields.CustomField;
import com.atlassian.jira.issue.fields.config.FieldConfig;
import com.atlassian.jira.issue.fields.layout.field.FieldLayoutItem;
import com.atlassian.jira.component.ComponentAccessor;
import com.riadalabs.jira.plugins.insight.channel.external.api.facade.IQLFacade;
import com.riadalabs.jira.plugins.insight.channel.external.api.facade.ObjectFacade;
import com.riadalabs.jira.plugins.insight.services.model.ObjectBean;
AssetLinkListener.java
import com.atlassian.jira.issue.CustomFieldManager;
import com.atlassian.event.api.EventPublisher;
import com.atlassian.event.api.EventListener;
import com.atlassian.jira.event.issue.IssueEvent;
import com.atlassian.jira.event.type.EventType;
import com.riadalabs.jira.plugins.insight.services.model.*;
import io.riada.insight.model.ObjectTicketConnection;
import org.springframework.beans.factory.DisposableBean;
import org.springframework.beans.factory.InitializingBean;
import org.springframework.beans.factory.annotation.Autowired;
import io.riada.insight.services.ObjectTicketConnectionService;
import java.util.ArrayList;
import java.util.Collection;
import java.util.List;
import java.util.regex.Matcher;
import java.util.regex.Pattern;
The error is coming from those io.riada imports. Those packages aren’t exported by the Assets bundle.
I'd suggest removing all io.riada packages and using com.riadalabs.jira.plugins.insight.channel.external.api.facade.*
and the public model com.riadalabs.jira.plugins.insight.services.model.ObjectBean.
As far as I know from my short search, these are the supported, exported classes/services.
With Java, you can resolve your Asset object using (ObjectFacade.loadObjectBean(...)), then write its key/id to the issues's Asset's custom field or call the Assets REST API (see this article: https://developer.atlassian.com/server/jira/platform/assets-app-development)
I hope it was helpful
Thanks very much. They are really helpful. And how can I write Asset's key/id to the issues' Asset custom field? Must I use REST API to do this?
That's a good question that I do not know the answer exactly :)
However I can share a code that might be helpful for you, but please be aware that I haven't tried this code, it's just the code I am adapting some code of mine and writing it here
CustomField cf = customFieldManager.getCustomFieldObject("customfield_xxxx);
ObjectBean obj = objectFacade.loadObjectBean(objectId);
IssueInputParameters iip = issueService.newIssueInputParameters()
.addCustomFieldValue(cf.getId(), String.valueOf(obj.getId()));
IssueService.UpdateValidationResult vr = issueService.validateUpdate(user, issue.getId(), iip);
if (!vr.isValid()) throw new IllegalStateException(vr.getErrorCollection().toString());
issueService.update(user, vr);
Don't fortget to import and inject objectFacade in the constructor or inject via annotation
private final ObjectFacade objectFacade;
this.objectFacade = objectFacade;
Hi @Tuncay Senturk _Snapbytes_ , thanks very much for your help. But it seems to not work. Maybe I don't express clearly. What I want to do is that when I create a ticket like "SIEM-14"and choose an asset like "Reference database". In the "Related Jira issues" area of "Reference database", "SIEM-14" will be added here like the official Asset Field.
I found an interface called "com.riadalabs.jira.plugins.insight.channel.external.api.facade.ObjectTicketFacade". However, it can just
findTicketsForObject
instead of creating connection between object and ticket.
Really Thanks very much for your lot of help. Wish you a good day.
Sorry, I wish I could assist at this stage but I can't as I don't know the answer
Oh please feel free about that, you have really helped me a lot. Thanks very much for your advice and kindness~
HI @Wenjing Liu ,
Have you reviewed this article?
https://developer.atlassian.com/server/framework/atlassian-sdk/managing-dependencies/
In any case,if you don't find a satisfactory answer here, I'd recommend to leverage the Atlassian development community as well (https://developer.atlassian.com/)
