Hello community,
I want to create an automate, which send to slack information about maintenance work in our company.
We have a field named: "Start of works" and this field is Date Time Picker with date and time.
I want to refer to this field, and try to do it like this jql :
start of works=now()
but it seems not working , because when the time from this field is appropriate the jql function nothing returns,
If there are any other solutions to integrate this ?
Hi @Sebastian,
Use this JQL instead:
"Start of works" > startOfDay() and "Start of works" < endOfDay()
It will return all issues with the current date in this field.
@Kseniia Trushnikovayes I know about it, but I want to refer to certain value date and time with this field, for example:
date and time from filed is: 07/09/2023 12:22
and when system date and time is the same – send notification,
@Sebastian, I don't think that's possible. I guess that would only be possible if a rule could be scheduled to run every minute to check the field, but rules cannot be scheduled at intervals less than 5 minutes.
You can try to create this rule:
This rule will notify of issues where the field value is less than the next 5 minutes.
