Hey all,
Did someone ever tried to create an automation that will copy value from one field which is not a custom field to anther field which in not a custom field?
In my case I want to create one, that will copy the values from component into Team.
I tried with Smart values, but it didn't work out.
Thanks !
Hi @Eran Roiter , I would be surprised if that would work given the context of these fields. I assume you have added components that equate to Teams you have created and you never add more than one component? I have never tried to set the Team in Automation. Have you done so? Can you share your current rule attempt?
Hi @Jack Brickey
In order to set a Team with automation you need to do this:
Go to Team's and look at the value of the Team you want to Set in the automation.
and write in the additional fields the next context.
This part is working, I'm trying to take it one step forward :)
