is it possible to add an extra field in the portal when customers are creating a ticket?
This field should be a radiobutton where the customers can choose of wich departement they are so that the assignee changes to the responsable helpdesk-agent!
Is this possible?
grtz
R.
1. Yes, it is possible:
- make respective field in JIRA custom fields
- add it to Create screen representing Issue type that Portal CRT is mapped into
- add a field in CRT setup in JSD Project settings
2. IMHO with radiobuttions UX will suck. Select list would be the latest. Then - if you want to make further actions based on that - I would suggest (for JSD on premise, of course) Insight for JIRA - based on its structures and references you can assign assignee or approvers, set other fields etc.
Thx Przemek,
step 2 is a little complex i think, can i use scriptrunner to handle this step?
grtz
R.
Sure - script runner or any competitor (e.g. automation for JIRA) would do that.
But it won't relate Reporter to the chosen location. It will only allow to set assignee on the scheme:
IF Location = XYZ THEN Assign to ABC
Yes that's what i need, just setting the right assignee!
I have a script but don't know how to implement with the choise made by a customer in the portal.
This is the script:
String userName;
switch(ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName("Afdeling").toString()){
case "AB": userName = "Sam";break;
case "CD": userName = "Sam";break;
case "EF": userName = "Peter";break;
case "GH": userName = "Peter";break;
issue.setAssignee(ComponentAccessor.getUserManager().getUserByName(userName))
Przemek,
if I use the automation tool with the "When","If" and "Then", how can i link this to the created custom field in my JSD Portal?
grtz
Rachid
You mean built in automation in JIRA SD? not really. rather Automation for JIRA add-on.
I see, do you know how can I achieve this with script runner?
grtz
Rahid
Not at hand - I would need to do that and test. And this is actually something I wouldn't have time for within next few days.
Ok Przemek,
thx a lot, I hope you will find a solution, i will also try to find a solution! Please reply me if you have tested this out!
Thx a lot and have a nice weekend!
grtz
Rachid
i Przemek,
did you had time to look for a solution?
thx a lot!
grtz
Rachid
Hi @Rachid Amajoud,
Yes, it is possible.
Go to Project Settings > Request types > Edit fields > Add a field
Tansu Akdeniz
hx, Tansu!
The field is added, but now i need the next step! When a customer makes a choice (radiobutton = <location>), the the assagnee must be set by a mapping Location/assignee!
thx
R
