Reference Fields Using Variable in Automation for Jira
Haddon Fisher
August 21, 2025
To support our quarterly planning process, our "roadmap item" issues have two sets of custom fields for each development team: one to hold their involvement in that roadmap item ([Team Name] Delivery Commitment), and the other to hold the size of that involvement ([Team Name] SWAGfest Estimate).
I have several automation rules which set one or the other field...for example:
  • If a team is identified as the owner or a dependency for that roadmap item, that team's "involvement" field is set to "Estimate Needed".
  • When a team provides an estimate, their "involvement" field is set to "Decision Pending".
This involves moving "between" the fields, and to avoid needing to maintain a lookup table per-rule, I am using regex string manipulation. This is hard to screenshot, but I've attached an example of how I am dropping\adding the right strings to create the name of the field I want to set, and then how I am making another variable called "JSON" which I then invoke in the third screenshot.
I've hit some edge cases that require me to look up the value of one field for a check before doing some action on the other. For example, if someone sets their "estimate" field to empty, I'd like to see if their commitment is set to "Tracking Only" or "Not Accepted" and if not, ask the team to review and re-set their commitment (i.e. you can't accept a roadmap item if you don't know how much effort it'll take).
My question is this:
Is there a way for me to tell Automation "this smart value or variable I am feeding you is not a string, it's a field reference"?
I.e. (and in super hacky mustache-ese) something like:
{{issue.{{variable containing field name}}.value))?
So I can go check the value of the other field? I suspect I could look it up using an API call, but that seems like total overkill.
Fig 1: Using Regex to get the new field name from the old.
Fig 2: Using the field name variable as part of a JSON update statement.
Fig 3: Invoking the JSON update statement to update the issue.
Bill Sheboy
August 21, 2025
Hi @Haddon Fisher
If I understand your scenario correctly, you want to just-in-time (JIT) get a field value, selecting that field based upon another reference.
As far as I know, there is no JIT interpretation of smart value expressions by-field available to customers.  If there was, rules would be even more powerful...and honestly, quite risky, unpredictable, etc.  (Last year, I experimented with this very idea quite a bit trying to build dynamic, tiny charts for emails in a rule and it never worked out :^)
Two possible workarounds:
  • As you note, use the REST API endpoint to perform a work item search and specify only that exact field in the fields parameter, and so that will be the only one in that attribute of the response
  • And the messy one: build a delimited, Created Variable, with all possible fields you may want to "get", adding their field name in the equivalent of key / value pairs.  Then split() that back into a list, and use a dynamic regular expression with the match() function to get the correct pair for the desired field, finally using text functions to extract the value.  This is a variation of the dynamic search method from an article I wrote last year.
ENTERPRISE
