×In the Project Management type of project in JIRA, we are attempting to produce reports that illustrate the progress at a component level.
We have identified the filter to apply and the method of grouping by Component.
When we generate the report we see a useful grouping of the issues(tasks) that belong to that Component.
However, each Component group does not list the name of the component (see yellow highlight below).
Is this a known issue or is there a better method of viewing this ?
Kind Regards
Zahir
See image of issue below
Hello, I'm not sure if this will help you if you need to list the issues individually, but if you could use a summary report, you might try the Two Dimensional Filter Statistics gadget on a dashboard.
I created one where the XAxis = Status and the YAxis = Components. The result was a list of the components, in each column a number showing how many issues for each component in each status.
I would like to know how you generated your report above, if you can share, thanks.
You can get this report by choosing
in the list of reports available to a Kanban type board, then seleting one of your filters and by selecting Epic Link as the statistic type:
MY problem is to configure which columns will appear on that report!
