I am trying to create an automation rule on Jira Service Desk which will do the following:
WHEN a comment is added
IF the comment is posted by an agent
THEN assign the issue to the agent that commented
But I can't get the 'THEN' statement that I am trying to perform - I can only change the assignee to a static assignee (so it will always be assigned to 'Bob', for example) or assign it to the 'Automatic' assignee which is the static assignee for the service desk whenever a new issue is created.
Am I missing something? Is there another way to perform this automation rule?
Any help will be appreciated :)
UPDATE: I eventually used post functions on transitions in the workflow to assign tickets when certain transitions are made
You may want to try Global Automation, I currently do not have Jira in front of me.
Jira Administration > System > Automation Rule (?)
You can create this using smart values
I eventually found another way to serve my cause :)
Thank you for your answer Raynard!
Awesome! I'm glad you were able to keep moving. Do you mind sharing the solution you chose just in case someone else may need it? =]
Sure :)
My main goal was to keep track on my Jira Service Desk agents, as they were not assigning issues to themselves when resolving issues.
So I did the following:
When an issue is being transitioned to 'Resolved' -> assign the issue to current user (by using a post function on the transition in the workflow)
Ah, I see.
That makes a lot of sense. I use validators for that, if they try to transition a message pop-ups saying "This ticket is currently unassigned". But assigning them the ticket when resolving/closing makes more sense =]
