Hey, I am trying to create a JQL query where a user creates a ticket, for Onboarding. However, the issue tracks a separate "Start Date". And I am wanting to display all issues, that have a 5 day difference between the issue's "Created Date" and the actual "Start Date". Can anyone help? Thanks community!
Hi @Greg Chapman ,
With script runner you can use a jql like
project=ABC and issueFunction in dateCompare("", "created = Start date+5d")
Thank you, we leverage "Power scripts for Jira" plug-in. Would the syntax be similar? (I'm fairly new to scripting).
i think you can use Automation for this. Example of getting the difference between dates
{{issue.customfield_10015.diff(issue.customfield_10016).minutes}}
@Jack Brickey , this is nice.. Can this be used in a jql?
Or should the value be stored on a field like a 'scripted field'?
do you mean a jql in a search or within the automation? TBH, i have not implemented so can't give you precise instructions. I do expect you can do this w/o needed a field to compare within automation. should be easy enough to try it out.
project=ABC and issueFunction in dateCompare("", "created = Start date+5d") can be used as a jql I suppose
@Jack Brickey we leverage "PowerScripts for Jira" and SIL manager as our tools for scripting. This is my first time using this, as I am fairly new to Jira scripting. I'm wondering how different the syntax is from what @Niranjan has provided. (Thank you, btw.)
Quite different. Automation is built into Cloud and it does not require any scripting. Basically it is a lego like automation tool where you select various options and populate conditions, values, etc. if you give it a quick try I think you will find it intuitive. Project settings > Automation
@Greg Chapman , It is not possible to compare 2 fields in JIRA by default.
Do you have scriptrunner? If yes, you can look at https://scriptrunner-docs.connect.adaptavist.com/jiracloud/enhanced-search.html#_datecompare
We actually leverage "Powerscripts for Jira" as our tool to write custom scripts.
Hello @Greg Chapman ,
I believe that you should use a JQL like this:
key in silJQLExpression('startOfDay(created) < startOfDay(#{Start Date} - "5d")', 'project = YourProjectKey')It would be nice if you had mentioned that you use Power Scripts in your question. In this case I would find your ticket faster.
Thank you!
