×To support our quarterly planning process, our "roadmap item" issues have two sets of custom fields for each development team: one to hold their involvement in that roadmap item ([Team Name] Delivery Commitment), and the other to hold the size of that involvement ([Team Name] SWAGfest Estimate).
I have several automation rules which set one or the other field...for example:
This involves moving "between" the fields, and to avoid needing to maintain a lookup table per-rule, I am using regex string manipulation. This is hard to screenshot, but I've attached an example of how I am dropping\adding the right strings to create the name of the field I want to set, and then how I am making another variable called "JSON" which I then invoke in the third screenshot.
I've hit some edge cases that require me to look up the value of one field for a check before doing some action on the other. For example, if someone sets their "estimate" field to empty, I'd like to see if their commitment is set to "Tracking Only" or "Not Accepted" and if not, ask the team to review and re-set their commitment (i.e. you can't accept a roadmap item if you don't know how much effort it'll take).
My question is this:
Is there a way for me to tell Automation "this smart value or variable I am feeding you is not a string, it's a field reference"?
I.e. (and in super hacky mustache-ese) something like:
{{issue.{{variable containing field name}}.value))?
So I can go check the value of the other field? I suspect I could look it up using an API call, but that seems like total overkill.
Fig 1: Using Regex to get the new field name from the old.
Fig 2: Using the field name variable as part of a JSON update statement.
Fig 3: Invoking the JSON update statement to update the issue.
If I understand your scenario correctly, you want to just-in-time (JIT) get a field value, selecting that field based upon another reference.
As far as I know, there is no JIT interpretation of smart value expressions by-field available to customers. If there was, rules would be even more powerful...and honestly, quite risky, unpredictable, etc. (Last year, I experimented with this very idea quite a bit trying to build dynamic, tiny charts for emails in a rule and it never worked out :^)
Two possible workarounds:
