Hi @Zaid Darras ,
Opsgenie does manage automatically adding users into the following week's shift / rotation - as long as it's configured with something like this:
^ The rotation is configure to rotate weekly. Currently User 4 is on-call. User 1 would take over on-call at the start of next week - as the participant list was cycled through and will restart.
Hope this helps. Let us know if you have any additional questions, issues, etc.
Yes. Were you looking for something else?
If you can better describe your use-case - or what you are trying to automate - we might be able to provide some suggestions.
We have two shifts A & B
Shift A - have 3 sections/shifts:
Shift A - From Mon - Thu & Sun (2 AM - 11 AM EST)
Shift A on-call 1 - Fri (2 AM - 11 AM EST)
Shift A on-call 2 - Sun (11 AM - 2 AM EST)
Shift B - have 3 sections/shifts:
Shift B - From Mon - Fri (11 AM - 8 PM EST)
Shift B on-call 1 - Mon - Fri (8 PM - 2 AM EST)
Shift B on-call 2- Sat - Sun ( 2 AM - 2 AM EST)
Every week the user in the shift A will be in the Shift B instead of the user in the shift B, and the user in the Shift B will be in the Shift A instead of the user in the shift A.
What the best way to create rule to replace each month for the four weeks the users between Shift A and Shift B automatically?
I'm not really following with "Every week the user in the shift A will be in the Shift B instead of the user in the shift B, and the user in the Shift B will be in the Shift A instead of the user in the shift A."
Seems like for week 1 - User 1 is on-call for Shift A / User 2 is on-call for Shift B, then week 2 User 1 is on-call for Shift B / User 2 is on-call for Shift A, and it continues to rotate every other week?
Regardless - this still should be configurable with 2 rotations - or multiple rotations in general.
Shift A rotation might look something like this:
I'm having a tough time following Shift B when users are on-call. You mentioned:
So does this mean each weekday shift is Mon 11am - Tues 2am, Tues 11am - Wed 2am, etc. ?
Regardless, my interpretation of this shift might look something like this:
With the final schedule looking something like this:
Hope this helps. Let us know if you have any other questions, issues, etc.
