I dont know why, but now i cant add an emodji to custom field, it is the worst udate i ever seen.
Does anybody know how to add emodji manually ? Or maybe there are another one power up with same function exist?
Hi Alexander,
Sorry you're having trouble with this. You should be able to add emojis to Custom Fields, both in the description field or the Custom Field title. You can go to https://emojipedia.org and search the emoji you'd like to use. Copy it and then paste it into the Custom Field. That should be able to help!
Thank you so much! 👍
Hey Alexander,
Just found out that, if you're working with Mac, this keyboard shortcut will also work: Command - Control - Spacebar to access emoji. 🎉💫
Is it possible to add the custom emojis (from business class) to a custom card name?
