×I have a datetime picker field called 'Event Started At' with ID 11726.
I want to define a smart value that will calculate the time between now and value of the above field.
In the automation, I added a Create Variable action:
Variable name: DTDuration
Smart value: {{now.diff(issue.customfield_11726).hours.abs}}
This works.
Later I have an Edit Issue action that inserts this variable value into a short text custom field, as a check:
DTD is '{{DTDuration}}'
The result is, as expected:
DTD is '123'
However, if I use this same variable to set a number custom field, the field value remains empty.
I tried to use {{DTDuration.format}}, but the field is still empty.
Any help is appreciated.
Thanks for the answers, but adding .asNumber does not fix the problem.
I have another project where a very similar automation works, so I have checked the differences.
This 2nd project also has the date/time CF Event Started At, ID=11726, which is set manually by the user, before the automation rule is triggered.
The automation rule is as follows (all are actions):
1. Edit another CF (type date/time picker) and set its value to {{now}}. This CF ID is 11544. Basically it's a placeholder to keep the value of now.
2. Re-fetch issue data
3. Create smart variable DTDUration using this formula - absolute time, in hours, time between the CF that holds the 'now' value and the CF of Event Started At:
{{issue.customfield_11544.diff(issue.customfield_11726).hours.abs}}
So it seems to me that even though the documentations shows that you can use now.diff(), it does not work. Put in other words, field_1.diff(field_2) works, but now.diff(field_2) does not.
Doc is here.
The next step for me would be to open a tech support ticket to Atlassian since if my theory is correct, it's either a bug in their code, or in the documentation.
Not sure about this as I have not tested, but could it be that the value is stored as text?? Have you tried using asnumber?
Hi @Amir Katz (Outseer) ,
try to convert the smart value/variable to a number with .asNumber
see the description in the link below:
https://support.atlassian.com/cloud-automation/docs/jira-smart-values-text-fields/
Best
Stefan
