Hi everyone,
I try to write an automation for when an issue's issue type changed from a certain issue types, change it back to what was it before. Let's say the issue type was x they changed it to y, change it back to x.
I can use JMWE(jira Misc Workflow Extension) or jira automation itself.
Any ideas how?
Thanks.
Hello @İclal Aslan
You can try with an automation rule where the trigger is:
When: Field value changes (Issue Type)
Then, add your condition(s) as needed.
For the action, choose Edit issue → Issue Type,
and use this smart value: {{fieldChange.from}}
More infos :
https://support.atlassian.com/cloud-automation/docs/jira-smart-values-issues/
Hope this can help :)
Thank you. But when I edit the issue typw how can i make sure it changes to the old issue type?
I was able to edit additional fields with @Duc Thang TRAN 's help. Thank you for your help! this helped a lot!
Hi @İclal Aslan
Even though you have an automation rule to set the work item / issue type back, I caution against using it, and instead investigate why the types are changing by discussing this with your team, then try to solve that root cause instead.
The caution / reason is work item types each have their own configuration and workflow, and changing types can be complicated. This is why Atlassian has a specific UX feature to manage this, Move, which asks the person questions to help guide the change. An automation rule cannot stop and ask such questions. Thus, the rule must anticipate all possible problems and solve them as part of updating the work item. Without this, the best case is the rule just fails to make the edit and the worst is the work item is left in an unstable state.
Hello @Bill Sheboy
Thank you for sharing this item. I agree with your point — I remember a case involving this action.
The ticket got stuck in a status after the issue type was modified via automation and couldn’t move forward.
This reminds me not to suggest this action in the future
One safer alternative with an automation rule is the REST API Bulk Move endpoint which may be called with Send Web Request action. I expect that to fail better when the move is not possible for predictable causes.
