Automation rule for setting cascade field values with a .CSV
Heydi Menéndez
June 24, 2024
2.15.1.0
Hello !!
I´m trying to generate an automation rule that sets a personalized cascade field (two values ) when another personalized field is edited but using a .csv . I´d been trying different ways with no success.
This is the example I´m trying to solve.
When "field1" is edited in the issue
search in the .csv the value selected for Field 1
then edit cascade field "parent name/ child name" with the registers of the row that corresponds to Field1 value.
Example of the automation :
If Field 1 is set with value 2 , then set parentname with parentvalue2 and childname with shildvalue2, sort of that
Example of the csv:
Field 1    Parent name    Child name
value1   parentvalue1    childvalue1
value2   parentvalue2    childvalue2
Sorry my english...I´ll appreciate your help!!!
Regards!
Tim Kopperud
@Heydi Menéndez, can you give some information where the rule fails? Are you able to import the CSV and read it within the automation? An image of yor failed rule might help.
It would be helpfull to know which part to focus on trying to help you solve this.
TimK
