I want to create an automation where the status of a parent issue (Initiative) transitions automatically based on the status of its child issues (Epics). Specifically, the Initiative status should change in response to the statuses of the Epics it contains.
when child epic transition to “Execution” parent status will be “Done”.
We have multiple Childs under the parent
Thank you.
Do you want to make a transition of a parent when any of the child issues move to Execution status or when all children reach Execution status?
1. trigger: issue transitioned - to Execution
2. Condition: issuetype equals epic
3. branch rule: related issue: for Parent
3.1 condition: related issues condition: Children all match JQL: status= execution
3.2.action: transition issue: to Done
* if your Epic workflow have one or more statuses after Execution (e.g. Status A, Status B) then you should modify JQL in step 3.1 as following:
status in (Execution, "Status A", "Status B")
@Banti what is the workflow of your initiative?
When automation is triggered, is the initiative Tp1-437 in a status that can be transitioned to Done (according to your workflow)?
@Banti according to your automation, only one status : "Retro Review" has transition to Done.
When automation is triggered if current Initiative status is not Retro Review, the automation will not execute.
1. You can modify automation step 3.2 to: action- transition from "Retro Review to "Done"
Or
2. You can edit your workflow in a way that more then one status can make transition to Done.
Or
3. You can set any status status can make transition to done. (DONE-all)
Also, I suggest you not to use Scrum Events as statuses. I suppose that Retro Review means retrospective & and sprint review and that should not be the part of the workflow.
Maybe you should think out how to optimize and align better your workflows for Epic and Initiative.
