Jira Automation - Add a "What changed" Text field for Jira Admins
Harald Mayer April 13, 2022
Hello everyone,
From my perspective, it would be great to have an additional text field in the automation rules after a change, where you can write more information about the changes, possibly also links to change requests or similar.
A "history of changes" within the automation rules would also be very nice.
What do you say?
br
Harald
Nic Brough -Adaptavist-
April 13, 2022
I don't think Atlassian will ever add anything like this.  Automations are self-explanatory and "active" - you rarely care about what they used to do, only what they do currently.
If you think you need to track changes to them, then treat them as code - create a Jira project to track requested changes to them
Brian Debler
I agree that this would be spectacular to see, even if it was in some raw text form separated by semi-colons.  I imagine something as a read-only Change Summary field, where one display or query for details without opening up the Change History one item at a time.
yes - i sometimes is not easy to unterstand what has changed in the rule. And also the text field would be nice to know from where this changes come - "requested by Mr X. via issue IT-XXX" for example.
br Harald
April 13, 2022
Do you mean explanatory notes within the automation rules?  Automation blocks are designed to be self-explaining.  Or do you mean a history so you can see who changed an Automation and demand that they explain why?
