How to create a sub incidente after to create a incident epic and associates?
Sebastian Toledo April 3, 2023
Hi guys,
I need to create several sub-incidents after creating an epic incident and that the automatically created sub-incidents are associated with the mentioned Epic.
They cannot be subtasks, but rather standalone Tickets such as Tasks or Stories.
This is possible?
Greetings and thank you very much
Sebastian Toledo April 5, 2023
Hello JC, thank you very much for your answer, but I think it didn't let me type "Copy from issue", then press the 3 dots and select COPY, it was automatically set to "Copy Epic Link from current issue".
I saved the changes and did the test, in the test it failed again since the Epic "master" ticket does NOT complete its Epic Link field, but its Epic Name field, for this reason the new ticket created is not linked.
Hello Juan Carlos,
Thank you very much for your answer.
Is it possible to link the sub issue as Epic and not as Issue?
I mean that this sub-incident stays with the Epic Link of the newly generated incident.
Example Good
Example bad
304 its bad / 306 it's good
It's possible?
Greetings and again thank you very much!
Juan Carlos Vera
April 3, 2023
Hi @Sebastian Toledo ,
To see this type of reation between Tickets,  You need to modify the Field "Issue link" in the same Autoamtion, and copy it from current issue (that is the epic created).
With this Automation you will have the Tickets like Childs of the Epic.
Sample here:
Hope it Help you ;)
Sebastian Toledo April 4, 2023
Juan Carlos Vera
April 6, 2023
Hola @Sebastian Toledo ,
me puedes mostrar un pantallazo?
Me resulta extraño que en el campo "Epic Link" no te salgan más opciones..
Juan Carlos Vera
April 3, 2023
Yes, it´s posible.
You can see a sample, that create a Story When an Epic is created, and linked the tickets.
