Our dev team has a few dozen Jira projects, one for each microservice - we'll use "PAY" as an example jira key for one of those. They use a single Jira project as their main board (MAIN as the key) and have the filter setup to view all projects in that single project board.
A review ticket gets created each sprint within the specific Jira project (PAY) so that all the work is tracked in the appropriate place, sometimes multiple review tickets get created in multiple projects. They do this for each sprint for whatever microservice they are working on.
I'd like to setup a template jira issue (in MAIN for exampel) in which they can just clone into the appropriate project, but i'm not sure how without having to specifiy each project. In the Clone Issue automation you're required to select the project. Seems like I'd have to set this up within each microservice jira project.
Was trying to think of a way to pull some sort of information from within the ticket like a label or something so that it gets moved to the appropriate project.
Any help is greatly appreciated and happy to provide more details.
Hi @Josh Allen
The create issue and clone issue actions for automation require selecting the project, as you note. And, I recall there is currently no REST API clone issue function.
Some possible workarounds are:
Okay, i feel closer but not quite.
The first automation works great. In my template issue I add the label SEAP and it will clone the issue into the appropriate project. However, my branching doesn't seem to work. If i add the label ADB instead of SEAP, the audit log says "No Actions Performed". Probably i don't understand how branching works.
Any thoughts?
So looks like this:
Are you trying to check for label values of SEAP or ACH?
If so, I believe your rule needs a different structure so it does not halt after the first condition test:
This allows each branch to proceed and the conditions to succeed or fail without impacting the others.
YES! Thank you. That was it.
The only thing, or most simple thing, i could do was have a template issue, then add the label for the appropriate project, then run the automation so it clones into that project.
This is great. Appreciate the help.
