Lock fields after adding data
Francisco Navarro
Hello community,
I'm struggling with an automation and I hope you can help. I have 3 date fields and 3 text fields. What I'm trying to do is prevent them from editing the value after entering data.
Currently, I've only managed to keep the data and return it to the original value if they enter something. Then I set up conditions based on "IF" and "ELSE" to go through all the fields, but now it doesn't do anything :(
I've attached images of the rule so you can better explain what I built and help guide me toward a solution.error automation3.pngerror automation2.pngerror automation1.png
Darryl Lee
Using Automation to revert fields that users are "not supposed to touch" is a pretty horrible user experience.
User: "What? Why did it change my field back? What is happening!?"
A better solution is to prevent editing of fields during particular statuses.
The way to do this is with Workflow Properties, a slightly arcane Jira Admin topic. Here's the official documentation:
And a great tutorial on it from @Bogdan Gorka:
And lastly, the great grand-daddy of resources from @Jobin Kuruvilla [Adaptavist]:
The property you would want to set for Statuses where fields should not be edited is:
  • jira.issue.editable = False
Francisco Navarro
Thanks!
I'll check out the instructions you shared with me.
Marc - Devoteam
August 15, 2025
Hi @Darryl Lee
I know about these options as well, but this would cause any field of the issue to be not be edited anymore in a certain status, not just some fields, correct?
Darryl Lee
Correct - it locks editing for all fields.
I think this didn't used to be such an issue before Atlassian introduced inline-editing in JIRA 5.1, because people had to go to the "Edit" button.
Anyways, for workflows that do require a bit more ... compliance, it always made sense to me that specific field changes be contained within specific Workflow steps and screens.
But yeah, Atlassian does not really advertise these properties nor make it obvious that you can do it.
(Haaaaaa, I bet the new Workflow Builder Agent does not know about Workflow Properties, @David Berclaz _Apwide_ )
Rick Westbrock
August 18, 2025
I find that you can reduce user confusion by having the automation rule add a comment to the work item explaining why it changed the value of a field. Not ideal but a decent workaround for some use cases.
Like Darryl Lee likes this
Darryl Lee
Oh for sure @Rick Westbrock, adding a comment is a necessity if you're going to be changing data after people change it.
I just can't help but put myself in users' shoes, and Jira allows me to change a field and I do so, I'd be kind of annoyed to then get a notification with a comment that says "We changed the field you edited BACK to it's previous value because you weren't supposed to touch that, even though the field was editable."
And sure, editing the field description is a good practice, and might help mitigate things.
My point being that Jira does give you the (admittedly overly-complicated) capability to "lock fields down", and in certain situations, that might make sense.
Francisco Navarro
Hello Marc,
What I managed to do was "revert" the value of the modified field to the original. While this doesn't comply with the concept of "locking" as such, it helps users know after the announcement that after entering a piece of data once, they won't be able to change it again.
The problem started when I added more fields because it recorded the first changed field and then copied that original value to another field that had been modified, from the list of fields we specified.
Marc - Devoteam
August 13, 2025
Hi @Francisco Navarro
That's why i provided this solution.
Use read-only text field to copy the initial value to and remove the fields from the screens, so that they can't be seen and/or edited.
Marc - Devoteam
August 13, 2025
You can't lock fields.
What you can do is of these fields are filled in on creation, create referenced custom fields of type read only.
Then in automation based on issue creation copy the values of these fields to the custom fields and show these fields on the edit/view screens and not the initial fields.
