×Hi!
I'm trying to set up a JQL to search and compare a custom field with an URL with the same custom field from other tickets with an URL.
Example:
"cf[11300]" = {{issue."cf[11300]"}}
cf[11300] is the field I want to compare and its name is "Chat Link[Short text]". I've tried on both formats, "cf[11300]" and "Chat Link[Short text]", but I always get the result:
Custom Smart Value JQL Search: "("cf[11300]" =) - Error in JQL Query: Expecting either a value, list or function but got ')'. You must surround ')' in quotation marks to use it as a value. (line 1, character 15)
The field after "=" is empty, looks like it can't get the info from the cf[11300] field. This field is always an URL, is that what's stopping the JQL from finding it? Or am I missing something?
Thank you for your help!
Hi @Tiago Leite
for reasons of deeper analyze and overview: could you please provide a screenshot of your automation rule and the special components that contain the jql and/or smart value?
Furthermore: could you try to add a "audit log" action to see if the value of the used smart value can be read.
And:
Did you also try a notation of smart value without "" --> eg. with
Best
Stefan
Hi @Stefan Salzl !
Thank you for your reply!
Here's a screenshot of the main core of this automation:
I've tried ID and name without "", both still got the same error, it's blank after the "=".
I've also tried "=" and "IS", instead of "~", but got the same outcome.
Hi @Tiago Leite ,
What kind of type is your custom field? is it text or URL field?
Could you maybe share a screenshot of an issue with that field for having a better overview?
Best
Stefan
Hi @Tiago Leite ,
guess I could figure out the problem:
I have no idea why the field type is added in jql search but as far as I could find out it´s no problem within the issue search but the smart value can´t resolve the [Short Text].
Following lookupIssue search worked on my side:
"Chat Link" ~ {{issue.Chat Link}} and id != {{issue.id}}
Please let me know if this was helpful.
Best
Stefan
Hi @Stefan Salzl ! Thank you, once again, for your reply!
I can't share the field itself, since it has internal information, but it's an URL. Before that field, when the ticket is created, the field has "${ChatURL}", but that information is not shown on the ticket itself.
When I tried the ""Chat Link" ~ {{issue.Chat Link}} and id != {{issue.id}}" I got the same outcome:
Custom Smart Value JQL Search: "("Chat Link" ~ and id != 5628902) AND (project in (12854))" - Error in JQL Query: Expecting either a value, list or function but got 'and'. You must surround 'and' in quotation marks to use it as a value. (line 1, character 17)
What exactly do you mean with „before“? when exactly does this action happen? Is the field/url set in a previous step of your rule? Could you please share the whole automation rule?
Furthermore could you please add a „log action“ action that only prints the value of the field to the audit log via smart value of the issue {{issue.Chat Link}} and check the result?
Best
Stefan
could you share a screenshot of your entire automation rule as well as the detailed configuration/settings of your lookupissues action?
This would help to get a better understanding of the whole context in order to find the right solution.
Best
Stefan
