I want to create an automation where i move a ticket from one board to another based on a status updated. One board is a scrum board and one is a kanban. I am able to move the tickets manually but I want to automate this process.
Also to note, the scrum board is team managed, and the kanban is company managed. I have tried this but i keep getting this error but I am not sure what it means:
"Can not create issue in project/issue type 10029/10049"
Thank you.
Hi @Doireann Casey , welcome to the Community. You can't move an issue between projects. I think you are trying to use the Move issue to board action which, as described in the action description, You can move an issue from the backlog to one of the board's columns, and vice versa. This occurs within the same project.
let me know if this makes sense.
thank you. So there is no way to automate that move? I can do it manually between both projects e.g. Project A Scrum to Project B Kanban but i want to automate the process since there will be a lot of tickets
Hi @Doireann Casey , no you cannot move issues yet (AUTO-549 ). You might look at this workaround- move-an-issue-to-another-project-using-automation
Thank you for your help, I got this working. Really appreciate it!
