Need help on automation with dates
Rosana Casilli
Hi all!
One of the project lead wants to classify some issue taking into account the hour and minute of the date created.
IF the issue was created after 19hs 00 min
 then
     update  customefieldx= Yes
else
    update  customefieldx= No
How can I do that comparission?
Thanks in advance
Ro
Bill Sheboy
May 8, 2024
Hi @Rosana Casilli
The rule could use the date / time function format() to get the hour from the created date / time, and then use rule conditions on the result.  Please look here to find additional options for that function: https://support.atlassian.com/cloud-automation/docs/jira-smart-values-date-and-time/#Date-format---
Dave Rosenlund _Trundl_
Also, check out this previous post and the answer provided by Mark Segall in the thread below.
I just threw away a suggested solution I was working on because I remembered to search the community first, and I see now that Mark is much smarter than I am. And so is Bill byh the way. 😉
Solved: Check is time is between range of time - Jira autoamtion
Best,
-dave
Rosana Casilli
Hi @Dave Rosenlund _Trundl_ !! thank you for your response...
I have tried to use what it is mentioned in that post.. but... I do not know why, the Hour and minute it is always showing the same value
I create a rule (on create issue)  where I compare this two values:
if {{issue.created.convertToTimeZone("America/Argentina/Buenos_Aires").format("H")}} equals 13
and
{{issue.created.convertToTimeZone("America/Argentina/Buenos_Aires").format("M")}} greater than 7
then
Edit issue, and here I update a field.
Since I tested and didn´t change the value when "I supposed" the condition was true, then before the condition I put a send mail with the values in the condition. What i see is at the time the issue is created, that the values for {{issue.created.convertToTimeZone("America/Argentina/Buenos_Aires").format("H")}} is 13 (that is correct), and the value for {{issue.created.convertToTimeZone("America/Argentina/Buenos_Aires").format("M")}} is 5
but the created date has 13:07
It doesn't matter how many times I create an issue ( in different minutes difference) the values that returns those smart values are always the same, it is always showing 13 and 5
Can you help me with this?
Thanks in advance,
Ro
Like Dave Rosenlund _Trundl_ likes this
I'm sorry to say that we've exceeded my Automation expertise, @Rosana Casilli . Maybe @Bill Sheboy will know.
He's a wizard, whereas I'm just a novice.
Like Rosana Casilli likes this
Bill Sheboy
May 9, 2024
For the format() function, "H" is the hour-of-the-day and "M" is the month-of-the-year.
Did you want to use "m" for minute-of-the-hour instead?
Like # people like this
Rosana Casilli
Thank you both @Bill Sheboy  and @Dave Rosenlund _Trundl_
a big mistake from my side!! it works!
