Text replacement with breaks
Ralf Fehling
July 17, 2023
Hello everyone,
I use the mail handler from JETI to create issues based on HTML emails. This works as desired.
Because the body has a complex table structure, the result needs improvement. I would like to use Jira Automation for this. Simple text replacementsr [replace(String target, String replacement)] work well.
I want to remove the table in the header. As can be seen in the picture, the text to be target is spread over three lines.
I tried to identify the breaks with different variants - \n, (\n), \r, (\r), \r\n, (\r)(\n), \\. Unfortunately without the desired success.
What am I misunderstanding?  Do you have a suggestion for me?
Thanks in advance!
Regards Ralf
2 accepted
Tim Perrault
July 17, 2023
Hi @Ralf Fehling
So it looks like it is using wiki notation. You could grab the the first 6 pipes and just replace it with nothing.
regex to grab the first 6 pipes: [|]{6}
Ralf Fehling
July 20, 2023
Hi @Tim Perrault
The idea is not bad. I tried the replacement. But it doesn't work :(
Do you have an idea why it doesn't work?
Regards Ralf
Tim Perrault
July 20, 2023
@Ralf Fehling
Yea testing that out I can't get it to work. We could just eliminate everything up to a certain point though. Are all the notifications in the same format? If so, you could use the below regex to match everything up to the 9th pipe and replace that with nothing.
^([^|]*\|){9}
Before
After
Like Bill Sheboy likes this
Arkadiusz Inglot
July 17, 2023
What if you use:
{{issue.description.substringAfterLast("*(color:#BE")}}
or simillar approache?
Ralf Fehling
July 20, 2023
Hi @Arkadiusz Inglot
Since I don't want to remove the entire header, this doesn't seem like a good solution for us.
Regards Ralf
Bill Sheboy
July 17, 2023
Hi @Ralf Fehling
I respectfully suggest it can be quite difficult to remove all the possible markup from the source *and* not lose any content within an automation for Jira rule.  If you can find a way to send the source email as plain text, perhaps try that first.
Ralf Fehling
July 18, 2023
Hi @Bill Sheboy
we get the mail from an external agency. Unfortunately, it is not possible for us to select the output medium.
In order not to lose information, I want to define and replace the target as precisely as possible.
Attached is a sample and my current automation rules: EML-File / Automation-rule
Regards
Ralf
