Trigger issue creation when an asset is created
ajtritt
June 11, 2025
You used to be able to use asset (i.e. Object) creation as way to trigger issue creation. Is that feature gone?
Bill Sheboy
June 11, 2025
Hi @ajtritt -- Welcome to the Atlassian Community!
Do you mean using the Object Created, Updated, or Deleted rule trigger:
https://support.atlassian.com/cloud-automation/docs/jira-automation-triggers/#Object-trigger
ajtritt
June 13, 2025
Hey @Bill Sheboy
Yes, that's what I am looking for. It appears that in the new UI you cannot access  Object triggers when you create the automation in a Project. I had to go to Jira Admin Settings -> Automation -> Global Automation and create a new Rule from there to get access to Object triggers.
Andrew
Like Bill Sheboy likes this
Bill Sheboy
July 9, 2025
Hi @ajtritt
Just following up to check if this answered your question.  If so, please consider marking this one as "answered".  That will help others with a similar need find solutions faster.  If not, please let the community know what help you need with the rule changes.
Thanks!
