I have a custom field that contains first and last name:
"displayName": "John Doe",
If I do either of these-
{{issue.fields.customfield_10173.displayName.split(" ").get(0)}}
{{issue.fields.customfield_10173.displayName.split(" ").first}}
It will return John, Doe
I want just John
What am I doing wrong? Thank you!
Ok, I figured it out. Because my customfield_10173 is originally a list of names, whether or not one or multiple are added, I had to do as follows:
{{issue.fields.customfield_10173.displayName.first.split(" ").get(0)}}
.first selects the first name of the list and then I can split up that name. Even if it's only one name to begin with.
Thank you so much @Bill Sheboy and @Duc Thang TRAN for assisting me!
Hello @Tyler Giles
If you want to get only John for John Doe
I can suggest you this smart value
It strange, work perfectly for me
@Duc Thang TRAN Thank you for the assistance Duc! Can you do my a huge favor and see what this returns for you:
{{issue.fields.customfield_10049.displayName.split(" ")}}
I am interested in seeing what a just a split will return vs what I am seeing. I see:
[John, Doe] or [Jira, Integration]
For troubleshooting purposes, I am interested to see if yours returns:
[Duc, Thang, TRAN] or something else.
Thank you for your time!
Hi @Tyler Giles
First, and guessing the field type is user select, perhaps try writing this to the audit log to observe what it returns:
display name for selection: {{issue.customfield_10173.value.displayName}}
first name for selection: {{issue.customfield_10173.value.displayName.split(" ").get(0)}}
If that does not help, please answer the following:
@Bill Sheboy --Will try! I am brand new to Atlassian, but not to software development or ITSM in general.
How exactly can I "try writing this to the audit log to observe what it returns"?
I have heard others mention this and I have been looking for documentation on how to do so. Right now, I am trying to familiarize myself with all of the smart values that I will need for my project, and to test returning values, I just have an automation that is emailing me per every issue opened.
So I am opening up a brand new test issue every time. If there is a way to test these without opening a new test issue, I am all ears! Thank you so much for your time!
There is a Log Action which allows writing information to the audit log for debugging / informational purposes: https://support.atlassian.com/cloud-automation/docs/jira-automation-actions/#Log-action
If you add that action in your rule, you may paste in the expression, run the rule, and review the audit log details to see what happens. You may add multiple log actions, at different points in the rule, when trying to assess progress.
Regarding your question about testing issue date, some tips are...
@Bill Sheboy Ok, I found out how to manual trigger to the log, this is huge!
The removal of .fields and the addition of .value seem to not be returning any data. Please see screenshot of my returns:
@Bill Sheboy I am assuming that this is a user selection field, as the request form only accepts users that we have in our JSM.
Before anything else, I recommend pausing to identify the type of field in the global custom field list, and its scope (i.e., JSM, Jira, both). That will clarify how to access its attributes in the rule.
This custom field type is a User Picker:
This seems to be defined outside of my current project, as it appears it can be assigned to multiple projects.
The key here is it is a multiple-select, user field.
And so the specifics of how you want to use the information will determine how to proceed:
