Depending on a selected "Division" custom field, with options: Group X, Group Y.
I want a specific person added as a Preset Approver.
I managed to find the customfield_10700 id that stores the approvers for that Approval step (different approvers for different statuses).
In my automation, if Division = Group X, I want to populate the Preset approver field with the reporter (as an example):
{ "fields": { "customfield_10700": [ { "value": "<accountid>" } ] } }
Where <accountid> is the approver's account id.
In my testing, if an approver is already in this custom field and I run this automation, the current approver is removed, but the new approver isn't added. The automation runs without reported errors.
Would love some help! :)
Figured it out!
{"update":{"customfield_10700":[{"set":[{"accountId":"5f241224cdb7b4001bd41227"}]}]}}
I've tried the following without success:
{"update":{"customfield_10700":[{"set":[{"approvers":"62b9844d268cac6e31c355ee"}]}]}}
{"update":{"customfield_10700":[{"set":[{"value":"62b9844d268cac6e31c355ee"}]}]}}
All run without errors, but the approver doesn't change.
