×Hello dear community.
I used the atlassian template to implement an automation which moves my parent issue to "Done" based on the child issues once they are closed.
I ran it but I get some warnings and I would like to know what is the reason.
I am attaching images with the details of the automation and the warnings.
Hi Francisco,
This is most likely on the final action in the rule where it does the transition. Can you share details of that action? If it is trying to set the Resolution field at the same time it is transitioning, that is probably your problem.
Check the workflow to see if there is a transition screen on that transition where the user selects the Resolution.
Just following up to check if John's suggestions answered your question. If so, please consider marking this one as "answered". That will help others with a similar need find solutions faster. If not, please let the community know what help you need with the rule changes.
Thanks, and kind regards,
Sorry, I managed to find a solution in a minute and forgot to close this, thanks a lot for the help anyway!
