×I'm having an issue converting an old JSD (Legacy) Automation which is using a "Customer Notification" template when sending e-mails. This template has elaborate formatting (HTML I believe). Because of this I decided to keep the "Send e-mail" portion of the Legacy Automation and transfer the other sections to the Project Automation (Automation for Jira).
My issue is that I'm having a problem trying to trigger the Legacy Automation. Here's an example that is not responding:
Anyone have any ideas on how my new Project Automation can trigger an existing JSD Legacy Automation.
Vince
I know this isn't the direct question - but would it not be easier to move the other rule to Project Automation, even if it has complex formatting?
Automation will work fine when the two rules are no longer in Legacy - and the effort to make the Legacy rule work could be spent moving the rule across.
You might not find many answers here otherwise, as many users (including myself) don't use Legacy Automation anymore.
Ste
Hi @Vincenzo Ciaravella ,
I agree with the answer by @Ste Wright.
Maybe the JSD Automation does not trigger because the action of adding a participant is executed through the REST API (by an automation rule) rather than manually.
Please note even the new Automation rules need to enable a checkbox on the Rule Details section to allow a rule being triggered by actions made by another automation rule:
Anyways, I'd also substitute the legacy rule with a new one.
Regards
