Hello all,
It seems that creating a useful knowledge base is harder than it should. We can't seem to find a proper solution and I turn to the community once again.
First, a short description of our current situation.
We are using Refined for our knowledge base. It looks great but we are running into some issues.
Refined Pro's
Refined Cons:
We have tried going with the built-in knowledge base which is the reverse of the pro's and cons. In short, not ideal either.
I have tried looking at other KB's but can't find a good solution that will work for us.
What are we looking for?
One option that we are open to is hosting the KB in a separate solution while redirecting customers to the built-in JSM customer portal when they need to submit an issue.
Are we looking for the goose with the golden eggs or are we just not looking hard enough?
I would love to hear what you are using, how you are managing it and what made you choose that solution over something else.
Hi Paul. Coming from nothing, we went with the JSM/Confluence KB. So far it is working for us. Starting out, I wanted to make sure we had the basic stuff for a Support Portal, and Confluence fits the bill. I know nothing about Refined, but wondering if the Refined for Confluence App for Cloud would help at all to get a bit of both worlds? If that app let you maintain in Refined but dumped them over to the Confluence KB so JSM can use them, that might work. I can take articles written by our developers for our internal confluence pages and copy them over to the KB so JSM customers can get to them. I needed something integrated, so right from JSM I can create the article if needed. Hope that helps.
Hello @Dan Breyen
Refined is a layer over Confluence that offers different options such as a custom domain and different layout options. It looks great and can be a very handy tool, were it not for the shortcomings that we are encountering now. From what I understand, this is nog something Refined (or K15t for that matter) can do something about since they are limited to what the Atlassian API supports.
Refined plugs into your Confluence space to display the knowledge base articles so you can still create the articles as you would normally do.
However, since we are using a custom URL, our customers need to jump through several hoops when signing up because they need to switch URL's.
Also, Refined does not support a language switcher macro to allow multi-language.
So we are torn between something that looks great and can be browsed (Refined) or something that works great but cannot be browsed (Atlassian).
We are looking at something where we can combine those features.
How do your customers like the KB? Is it seeing much use? How do you handle the option to navigate the KB?
Hi Paul, I guess I'm trying to get a better understanding of what 'navigate the KB' means for you. The search works in JSM. As customers are typing in words, it's suggesting articles. And by putting labels on articles, there's also a keywords search. We're still pretty new to JSM and getting our customers accustomed to using JSM, but I haven't heard any complaints. Our goal for all of this is to get to the point where questions are being deflected due to the KB. I've used different Support Portals from Atlassian's competitors, and from a Support Perspective, integration is an important feature, so you can link articles and easily search them.
It's also easy for your Support Analyst to attach a KB article to the Service Request and get that information back to the customer. Hope that helps.
What I mean by navigation is that a customer can open a section and browse the knowledge base instead of having to search for them,
This will allow customers to read up on different sections of our product without having to search for it. They can jump back and forth to articles that interest them and perhaps find section that are unknown to them.
The default portal works great for searching and suggesting articles, it is not so great for browsing articles.
Refined has the ability to read a Confluence space, and display the page, including all the different sub articles. A quick example:
Hi Paul,
Raj from Refined here, came across your post and I might have some input that could be useful (no sales pitches, I promise).
Some background, to make sure we're on the same page: We've got two primary Atlassian cloud apps - Refined for Confluence Cloud, and Refined for Jira Cloud. We're set up as a SaaS on cloud, integrating with Atlassian cloud- which means that you can create Refined sites parallel to the native Atlassian Confluence / Jira instance, and pick and choose what Spaces / Projects are shown on each Refined site.
The two apps can be used independently of each other, or together. So you can use Refined for Jira Cloud and just use the JSM aspects of Atlassian on your Refined sites (and this comes with the native JSM project to KB connection), or use Refined for Confluence too, and actually add the Confluence Spaces on to your Refined sites. Here's a short video showing how these work and the differences.
With this in mind, let's take a look at your list of requirements:
Hope this helps, let me know if anything is unclear or if you need any more info.
