Automation Help!
Ben Weisman
Hi all,
   Desperately seeking help related to the devops automations. I am trying to create automations where when PRs are created and then merged we're moving the tasks associated along the workflow.
Seems simple enough but my question is: will the automation ONLY move the tasks associated to the PR?  I would think this to be the case but wanted to make sure because it doesn't specifically state it. I don't want to accidentally move EVERYTHING.
Mark Segall
Hi @Ben Weisman - I know you mentioned me for this one on another question. Unfortunately, DevOps automations are not in my wheelhouse just yet (I don't even have a Bitbucket sandbox to play in)
Ben Weisman
Ok, no worries. Thanks.
Boyan Angelov (Nemetschek Bulgaria)
March 22, 2022
Hi Ben,
I don't think you should be using Jira Automation for this. Looks like your best option is to use Workflow Triggers as explained here:
https://support.atlassian.com/jira-cloud-administration/docs/configure-workflow-triggers/
Boyan
Ben Weisman
The DevOps automations are used for this.
