Hi all,
I have the following problem. I need to create a Jira-Issue with some Insight-attributes but the insight automation functionality of "create a Jira issue" is not enough (setting approver e.g). So my idea was to create a script which can handle this. I fail already to create a simple Issue. The following script works fine in scriptrunner but it doesn't work as an insight automation.
import com.atlassian.jira.issue.context.IssueContext
import com.atlassian.jira.issue.context.IssueContextImpl
import com.atlassian.jira.issue.fields.config.manager.PrioritySchemeManager
def projectKey = 'Test'
def issueTypeName = 'Service Request VPN'
def reporterKey = 'testuser'
def summary = 'my summary'
final description = """ some text
def issueService = ComponentAccessor.issueService
def constantsManager = ComponentAccessor.constantsManager
def loggedInUser = ComponentAccessor.jiraAuthenticationContext.loggedInUser
def prioritySchemeManager = ComponentAccessor.getComponent(PrioritySchemeManager)
def project = ComponentAccessor.projectManager.getProjectObjByKey(projectKey)
def issueType = constantsManager.allIssueTypeObjects.findByName(issueTypeName)
def reporter = loggedInUser
def issueInputParameters = issueService.newIssueInputParameters().with {
setProjectId(project.id)
setIssueTypeId(issueType.id)
setReporterId(reporter.name)
setSummary(summary)
setDescription(description)
def validationResult = issueService.validateCreate(loggedInUser, issueInputParameters)
assert validationResult.valid : validationResult.errorCollection
def result = issueService.create(loggedInUser, validationResult)
assert result.valid : result.errorCollection
the following exception will be thrown
AutomationRuleGroovyScriptAction, Unexpected error: No signature of method: com.google.common.collect.RegularImmutableMap$Values.findByName() is applicable for argument types: (java.lang.String) values: [Service Request VPN]
groovy.lang.MissingMethodException: No signature of method: com.google.common.collect.RegularImmutableMap$Values.findByName() is applicable for argument types: (java.lang.String) values: [Service Request VPN]
at org.codehaus.groovy.runtime.ScriptBytecodeAdapter.unwrap(ScriptBytecodeAdapter.java:71)
at org.codehaus.groovy.runtime.callsite.PojoMetaClassSite.call(PojoMetaClassSite.java:48)
at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCall(CallSiteArray.java:47)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:116)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:128)
at createJiraIssue.run(createJiraIssue.groovy:51)
at groovy.lang.GroovyShell.evaluate(GroovyShell.java:574)
at groovy.lang.GroovyShell.evaluate(GroovyShell.java:621)
at com.riadalabs.jira.plugins.insight.services.core.impl.GroovyServiceImpl.evaluate(GroovyServiceImpl.java:86)
at com.riadalabs.jira.plugins.insight.services.automation.action.AutomationRuleGroovyScriptAction.doActionSafe(AutomationRuleGroovyScriptAction.java:99)
at com.riadalabs.jira.plugins.insight.services.automation.action.AbstractInsightAutomationAction.doAction(AbstractInsightAutomationAction.java:107)
at com.riadalabs.jira.plugins.insight.services.automation.rule.impl.AutomationRuleEngineImpl.executeAction(AutomationRuleEngineImpl.java:669)
at com.riadalabs.jira.plugins.insight.services.automation.rule.impl.AutomationRuleEngineImpl.executeActions(AutomationRuleEngineImpl.java:654)
at com.riadalabs.jira.plugins.insight.services.automation.rule.impl.AutomationRuleEngineImpl.matchConditionAndExecuteActions(AutomationRuleEngineImpl.java:453)
at com.riadalabs.jira.plugins.insight.services.automation.rule.impl.AutomationRuleEngineImpl.executeAsConfiguredUser(AutomationRuleEngineImpl.java:261)
at com.riadalabs.jira.plugins.insight.services.automation.rule.impl.AutomationRuleEngineImpl.handleAsyncEvent(AutomationRuleEngineImpl.java:214)
at com.riadalabs.jira.plugins.insight.services.automation.event.AutomationRuleEventListener.onAsyncEvent(AutomationRuleEventListener.java:94)
at sun.reflect.GeneratedMethodAccessor4705.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at com.google.common.eventbus.Subscriber.invokeSubscriberMethod(Subscriber.java:87)
at com.google.common.eventbus.Subscriber$SynchronizedSubscriber.invokeSubscriberMethod(Subscriber.java:144)
at com.google.common.eventbus.Subscriber$1.run(Subscriber.java:72)
at com.atlassian.sal.core.executor.ThreadLocalDelegateRunnable.run(ThreadLocalDelegateRunnable.java:34)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
It would be fine if anyone could help me, maybe there is also a different way to create Jira Issue with insight automation to set an approver an other fields with values of insight.
The "findByName" is an extension to the collection method that Adaptavist adds within scriptrunner.
Change it to
def issueType = constantsManager.allIssueTypeObjects.find{it.name == issueTypeName}
