Hi
I would need help in determining what is wrong with my smart value/ JQL for lookup issues automation.
The logic of the automation:
customfield_123 contains company name so ideally, the JQL should find only those "OS updates" which match the value of customfield_123 that is present in the trigger issue. (Deploy advanced compare perhaps?)
Problem:
Automation:
I was able to achieve what I wanted. The JQL was not correct in terms of syntax. Here is what worked:
issuetype="os update" AND "company name" ~ {{customfield_11943}}
