I created an automation rule for when a ticket remains In an On Hold state (using the On Hold status) for 5 days without an update, this rule will email the Assignee. The problem I am having is that the JQL query is erroring out saying that "The value 'On Hold' does not exist for the field 'statusCategory'." The On Hold status does exist, and is in use in a workflow I created. The JQL query is: updated <= startOfDay(-5d) AND statusCategory != "On Hold"
If I change On Hold to In Progress (another status) it works, but if I create a new status and try it, it does not work.
Thanks for any assistance you can provide.
Hello @jesse.hogan
Addressing the error you get in your rule:
There are two different fields related to Status. They are Status and Status Category.
"Status" is the field that holds the current status assigned to an issue. The values you see in the Workflow are stored in the "Status" field.
"Status Category" is the grouping to which each Status value is assigned. There are three Status Categories:
If you want to search for issues in a specific status (i.e. 'On Hold') you need to use the "status" field in your JQL:
updated <= startOfDay(-5d) and status != "On Hold"
You can use the "Status Category" field in your JQL as a short hand to reference all statuses in a particular category. For instance if you wanted to find all issues that are assigned a green lozenge status regardless of the actual word for that status (i.e. Done, Closed, Completed, Rejected) then you could use the Status Category field and the appropriate one of the three values I mentioned above:
statuscategory = Done
If you have additional problems with your rule after you update your JQL, in your next reply please post screen images to show the complete rule you have constructed, and a screen image that shows the rule's Audit Log details for an execution of the rule where you didn't get the results you expected.
Wow, thank you very much for your thorough reply. That worked!! This is my first time using JQL queries besides some very limited searches. Thanks again.
Interestingly, this applies to every custom status I have created and exists in a workflow. Only predefined stuff like In progress works.
