Problem with custom field not shown in transition validator
Rosana Casilli
Good afternoon All!
A user from the company that is starting to work with Jira Service Management have this problem.
The jira Admin created a field named "Product", this field is a single list field and has his context a values defined properly.
It is also included in the field configuration screen for the project he is working on.
This field is also inclued in the project screen and in a transitions screen.
But, when he tries to add a requried field validator in the transition where this screen is added, this field is not shown.
I tried to check with all aboved and everything look okay. Anyway I attached some screenshots to show you so maybe you can help us.
The image below is from the transition screen.
The image below is from the field configuration it is inclued not only in the transition screen that is highligthed but also in the thrid screen from top that is the default scren in the project,
and the last screen that the user provided is the onw from the context configuration of the field
thanks in advance
Ro
Adolfo Casari
August 1, 2024
@Rosana Casillithe last screen shows that Product is available only for project Lumina Support and for one issuetype. In this case the transition has to be one for the workflow that corresponds to that issuetype in project Lumina Support, otherwise it won't be shown in the transition screen.
Rosana Casilli
I need to check  with the user. But as far as I know, the issue type is associated to the workflow. But let me check with him.
Rosana Casilli
Hola Adolfo!!! el flujo de trabajo está asociado al tipo de problema y la pantalla de transición está asociada a esa pantalla de flujo de trabajo
Nicolas Grossi
Banned
August 1, 2024
@Rosana Casilli Are you sure that you are in the correct project ? Correct issue ? and correct screen ?
Rosana Casilli
I am sure the screen is correct
Rosana Casilli
Hi Nicolas!! yes now I am sure that it is associated to the correct project, correct issue and correct screen
