Jira automation regarding Web Links
Georgi Doychev May 31, 2022
Is there someway when new ticket is being created an automation to add a Web Link in the concrete issue type.
Example: We are getting Incident issue type (alarm) and we want to add Web Link in every auto generated alarm there? Is there an automation to do add concrete web link in each ticket instead of adding on-hand?
Thanks in advance!
3 votes
Aron Kuch
If your need (and subsequent readers) is the same as mine, I just automated it by making an API call ("Send web request" in Automation) to Create or update remote issue link: https://developer.atlassian.com/cloud/jira/platform/rest/v3/api-group-issue-remote-links/#api-rest-api-3-issue-issueidorkey-remotelink-post
Filipi Lima
May 31, 2022
Hello, Georgi! Welcome to the Community!
It sounds doable but we'd need to understand exactly where you'd like to add the Web Link.
Is it on a comment, an issue link, description?
Is the Web Link variable and if so, what are the variables?
What do you mean "concrete" issue type - is that an issue linked to the alarm issue?
Automation for Jira can make use of available fields to compose the web link and we can use actions to add a comment or edit a custom field on your issue.
Georgi Doychev June 2, 2022
Hello @Filipi Lima ,
Thanks for your response!
Kindly check the screenshots which I will attach for reference below.
I would like to make an automation to add web links in every auto generated ticket to my project.
Is there a way you would advise me to do this?
Thanks in advance!
Best Regards,
Georgi
Filipi Lima
June 2, 2022
Hi, Georgi,
I see that Automation for Jira currently doesn't support managing web links through any of the available actions. This is the open request:
https://codebarrel.atlassian.net/browse/AUT-176
Depending on your use case, you may add an actual URL to the description or or a comment by editing it through automation on specific scenarios.
While this may not be what you're looking for, I'll provide the link below in case the weblinks are issues from other Jira instances:
https://confluence.atlassian.com/jirakb/how-to-create-and-link-remote-jira-issues-using-automation-1085209850.html
Lastly, on this discussion someone provided a potential workaround using customfield:
https://community.atlassian.com/t5/Jira-Software-questions/Is-there-a-way-to-add-Web-link-Remotelink-using-Automation-for/qaq-p/1453035
Hello Filipi,
Thanks for your time on your research and investigation.
I can see that one of your colleagues have opened a ticket towards the dev team regarding this automation rule
https://jira.atlassian.com/browse/JSDCLOUD-11397
BR,
Georgi
Like Filipi Lima likes this
Guess_ Brandi N_
January 29, 2025
@Filipi Lima the code barrel link you have given just says I do not have access. can you confirm if it is still not possible to copy weblinks from one issue to another using automation? and how about the links to confluence content?
