Hi dear Community,
unfortunately I'm looking an answer for this simple problem but there is not...
I checked also old posts, still nothing.
my SLA is very simple but "counter" does not stop.
when ticket creates, SLA starts to count and when I response to customer, it stops and our target is 24h.
and these are some examples.
Thanks for your help
Best Regards
Yigit.
Hi @Y_ Oezl
This could happen because of different reasons:
You might need to dive deeper into your Jira configuration, or if you don't find the reason, you may need to open a ticket to get support from the Atlassian team.
Also, as an alternative solution, you may try to configure your SLA with the help of the add-on such as SLA Time and Report for Jira (developed by my team).
Hello Yuliia,
Thank you for your answer. I checked our automation rules, but there is nothing about SLA or something like that.
I guess, it's a bug but I will contact with Atlassian Support.
Thanks for your help again.
Best Regards
Yigit.
