Hello, again,
If I install this add-on, what will happen to the existing automation (the one comes with the system). Will it override it? and what happens if we have both? I'm trying to prevent a disaster before installing it :)
Hi there,
thanks for your message!
If you install Automation for Jira - it just means you have 2 automation engines. One won't disrupt the other so you will have the best of both worlds :)
Many other customers do this.
I hope that helps.
John
