using automation with Insight
Mourad Marzouk
I'm trying to edit an insight objet using automation, but it always says no objet to edit. I don't see a way to tell it what object to edit. How would you make this work?
5 votes
Mikael Sandberg
You should be able to do that if you use the IQL branch statement as a select and then update the object. Your other option is to use the REST API and do a send web request to Insight and update the object that way.
3 votes
Linda Milne_Togetha Group_
What do you want to edit? Do you mean you want to edit the attributes within the object? In that case you can use "Edit Insight Object Attributes" for all attributes you want to change.
