×Hello all!
I´m looking for a proper solution to duplicate and synchronise tasks automatically between JSM and Jira Software.
We are using the free plan JSM atm and want to keep it like that. Therefor we need to duplicate and synchronise every incoming task from JSM to our existing Jira Software instance.
Does anyone know a proper solution? Maybe any AddOns you can suggest?
I already checked the "Elements Copy&Sync" but it´s not possible to use it over different instances..
Deep Clone would be a solution to clone tasks but there we do not have an option to synchronise automatically.
Otherwise I have to configure it all by myself via the automation (trough APIs)
Thanks in advance!!
BR
Hi @Natalya Ozhigova ,
that was also our first thought. But after configuring some webhooks I realized, that it would be much easier and less prone to errors if we use a proper application. There are enough on the market.
Right now I will try to configure the synchronisation with Backbone.
BR Dennis
Hi @Dennis Orban ,
Our JSM DC instance and our JSW DC instance are not on the same instance. So what we did is acquire Backbone to allow us to create and synchronize a JSM issue. We don't synchronize everything because the workflow and automation in JSM is complex BUT we create the issue in JSW, so the Product owner can see all of his/her backlog in one place.
You will need 2 Backbone licence, one for JSM and one for JSW
Carmen
@Dennis Orban, if you need help setting it up, let us know via help@k15t.com.
Matthias.
Member of the Backbone team.
What about automation with webhook?
At first rule in JSM project: trigger - issue created and action - Send web request.
You can post all required data to the web request.
The second rule in the your software project
trigger - incoming webhook
action - create issue
For updating you can create similar rules. It looks a bit tricky but it works for free jira without any limitation.
Hope it help you
Best regards
Natalya
Not the form itself, but the fields contained therein should be synchronized over. We would need to see the use case and implementation a little more detail though for a detailed answer.
Hope it helps.
Majid
Hi @Syed Majid Hassan -Exalate-
if I use JSM with Jira Forms (former ProForma AddOn), is the form also beeing synchronised between two different instances?
Best regards
Dennis
This is Majid @ Exalate.
To continue the trend already set up, please feel free to review our add on Exalate. It seems that the caveats you mentioned already are fully addressed in Exalate i.e. the bi-directional sync and automation. The solution can be implemented within minutes and allows you very granular control on the data being shared between the 2 instances.
If you would like to see a customized demo of the product, please book a slot with us.
Majid
Hi @Dennis Orban
As Carmen already suggested, there are a few Marketplace 3rd party apps that allow you to integrate Jira Service Management and Jira Software across multiple instances and hostings.
I'm part of the team responsible for Issue Sync - Synchronization for Jira. Our plugin allows you to integrate Jira Service Management and Jira Software on Server/ DC and Cloud. It creates issues in remote projects automatically and keeps them in sync also when their data (as field values, statuses, or comments) change.
If that sounds interesting to you, feel free to test the app with our 30 days long trial. Might you have any questions about the product - we are here to help!
Kasia from Deviniti
