Automation creates child issue but won't copy values
Jennifer Joyce February 7, 2025
The purpose of this automation is to create a Change Ticket from an open Issue. I need some of the values of the original issue to copy over to the new issue.  I created an automation to trigger on demand from an issue.  It will create the change ticket in another project using "Create issue with Request type"  (it would not work with Create Issue action, as it kept failing saying request type is required and it won't let me set the request type in the action.)  The "Create issue with Request type" only lets me set the Summary and Reporter fields, so I am trying to set the remaining fields further down.
i then have a "From most recently created issue" branch where I update this new child issue.  The request type is changed (this works fine) and it links the new issue to the original issue (works fine) but the Edit Issues field is not working as expected.  It reports "successful" in the audit log, if I hard code values for these fields that is successful, but the "Copy from Current Issue" values all do nothing.  I also tested using a smart field and that also did nothing.  The fields are the shared between the two projects, so they're all the same data type.  The first field (Systems Affect) is a multi-choice drop down, the rest are all paragraphs.
What am i missing here?
4 votes
Jack Brickey
Is the option copy from trigger issue available?
Bill Sheboy
February 7, 2025
Hi @Jennifer Joyce -- Welcome to the Atlassian Community!
Adding to Jack's answer:
When the rule is inside the branch, "current issue" and "issue" refer to the branched-to issue.  In your case, that is the most-recently-created-one.  Instead you want to copy from the "Trigger Issue".
I continued playing with this and googling after posting as I suspected that was the case.  I was able to get this working by using smart values like {{triggerissue.my field}}.
HOWEVER.. for anyone coming after me, I have only just now realized that "Current Issue" is clickable and has a selection where I can choose Trigger issue.  <facepalm>  I think if I had noticed this earlier this may have saved me hours of frustration...
Thank you both!
Like Jack Brickey likes this
