Hi @Michael Catmur -- Welcome to the Atlassian Community!
For a question like this, context is important for the community to help. Please post the following:
Until we see those...
Are you using the built-in Start Date and End Date fields, or did you create additional custom fields with the same names?
What are the types of your fields: text, date, or date / time?
Hi, thanks for the feedback:
While this won't solve your issue, it will help with what you are trying to do.
Change your statement to:
{{#Debug}}{{issue.customfield_11124.concat("T").concat(issue.customfield_11248)}}{{/}}
Then post the output here. If you get an error, post each piece separately so that we can see your data
Thanks, for that. I tried it, but unfortunately get no extra info in the audit log
