Hi @Michael Catmur -- Welcome to the Atlassian Community!
For a question like this, context is important for the community to help. Please post the following:
Until we see those...
Are you using the built-in Start Date and End Date fields, or did you create additional custom fields with the same names?
What are the types of your fields: text, date, or date / time?
Hi, thanks for the feedback:
moved on a little now.. have managed to get a custom field StartDateTime_Concatenated (issue.customfield_11578) as a string using:
{{issue.customfield_11124.format("yyyy-MM-dd").concat("T").concat(issue.customfield_11248).concat("Z")}}
this is storing values like "2025-08-21T10:10:10Z" in a string field.
Now i need to convert that ISO datetime into a proper datetime value. I tried these: but get no value populated and no error message from the automation.
Any suggestions?
While this won't solve your issue, it will help with what you are trying to do.
Change your statement to:
{{#Debug}}{{issue.customfield_11124.concat("T").concat(issue.customfield_11248)}}{{/}}
Then post the output here. If you get an error, post each piece separately so that we can see your data
Thanks, for that. I tried it, but unfortunately get no extra info in the audit log
