What do you mean by "password management tool"? A password safe to keep your passwords in? Or a user management tool that handles users (I'm guessing you may be wanting to talk about password strength and expiry stuff, which should be part of the user directory system, not a separate tool)
I mean an application like the Passman Connector for Jira. I just wanted to know if there are any other recommendations
I'm not familiar with that app, could you explain what problem you're trying to solve?
Hi @[deleted] ,
Atlassian Access allows you to set authentication/password policies across organizations.
Refer:
Understand authentication policies
Regards
Utkarsh
