my custom field Select List (cascading) type does not appear in automation. I need it to create a record to Jira Software.
does Select List(cascading) still not supported? is there another way to do it?
This can be done in the More Options section of the Create/Clone/Edit issue actions:
{ "update": { "CUSTOMFIELD": [ { "set": { "value": "{{triggerIssue.fields.CUSTOMFIELD.value}}", "child": { "value": "{{triggerIssue.fields.CUSTOMFIELD.child.value}}" } } } ] } }
You would replace "CUSTOMFIELD" with your custom field name
Hope this helps
@Mar Angelo L_ Tareno is your query is solved by using this or still you are facing an issue in Automation
Hello @Mar Angelo L_ Tareno ,
Try steps mentioned in this Document--> https://support.atlassian.com/jira/kb/set-value-for-cascading-field-with-jira-automation/
You can use the values below under Additional fields, which is available under More options in the automation
Value of the parent:
{{issue.fields.Cascade.value}}
Value of the child:
{{issue.fields.Cascade.child.value}}
I have cascade select on JSM and I need to Insert it to Jira software cascade field. but the field does not appear in selection.
