I have a custom field called "Checked By" which is a single select drop down list. I want to set this field when a user triggers a certain transition. It should be assigned the name of the user who triggered the transition. I am using Jira automation to accomplish this. For some reason I am unable to capture/assign the "User who triggered event" value to this custom field, though this is not a problem when trying to set this to an Assignee. I am pretty sure this has something to do with the Data Type. I can't figure the right smart value for this value either. Had no luck when I tried to implement this as a Post-Function in the WorkFlow.
Hi @Ragvi Ttpt
The smart value you want is the {{initiator}}, and specifically you may need {{initiator.accountId}}
Try both to see what happens when setting your field.
Best regards,
